Overnighter Rod Storage
Rod storage in the small cutting cabin of the overnighter can be a problem. To prevent rods from being damaged it’s a good idea to get them up and out of the way and not leave them on the cushions. Here is one solution to that problem. I decided to mount rod holders using three bolts which hold the Cutty cabin bulkhead wall to the sides of the boat.
Here is a photo of the rod holders I fashioned from 1/8” aluminum sheet 8” wide and bent into a 90 to hold the teak rod supports.
https://flic.kr/p/DYdYVs
This photograph shows the location. One on each side of the cabin.
https://flic.kr/p/Eqm22M
And here are the holders bolted into place. I removed the original washers to help compensate for the thickness of the aluminum. You will heed an assistant to thold the bolts head on the outside of the cabin as you remove the nuts on the inside. Same for tightening the bolts.
https://flic.kr/p/DRRmy6
Next you will have to drill holes in the fabric bulkhead to allow the rods to be supported on their front ends. Use a sharp utility knife, cut an X pattern in the fabric and peal it back to reveal the plywood bulkhead. Tape the fabric out of the way as you cut the hole, be generous, 2” might be about right and when locating the hole; consider the cabin sides slope in sharply beyond the bulkhead. If you have long rods move over farther toward the centerline than I did.
https://flic.kr/p/Eo2gQL
Now use contact cement and apply glue to the plywood on both sides of the bulkhead where the fabric will contact it when you carefully stretch the fabric back in place thru the hole. Allow the glue to dry and place the fabic back in place thru the new hole.
https://flic.kr/p/Eo2GYb
Here the completed assembly with the rods in place.
https://flic.kr/p/DsBxEL
https://flic.kr/p/DRRpEM
Thanks, BCBryan.
Thanks, BCBryan.
