- Apr 5, 2020
- Age
- 44
- CHOOSE
Good morning (AK time).
I’m having mid to low RPM surging issuesw my 2005 Saltwater Series OX66 200hp. For the full story and diagnostics it’s all in the “OX66LP pumps” thread.
HOWEVER, my current thought is the TPS. When I test resistance, w cylinder 1 disconnected and fully closed, I’m measuring about .9 and fully opened about 4.5.
This seems high on the low end and low on the high end.
Also, when slowly moving throughout the throttle range it’s not a nice steady increase in resistance.
One more thing, the resistance jumps around a bit when I tap on the TPS with my finger.
Questions:
-How can I test voltage of TPS without the having the special wire harness?
-can I expect voltage results to be different from my resistance test?
-Should I attempt to adjust my TPS? It never has been (still has yellow dummy paint on screws)
-is this normal behavior for TPS? (Fluctuations when tapped and not smooth increasing resistance)
-where can I buy the test harness?
Thank you so much for all help and ideas! I hope everyone is doing well able to find and spread a little joy this weekend.
Questions:
