I just purchased a 1981 Pacific 221 (small walk-around cuddy/inboard-outboard). Bulkheads below the deck in the cockpit create 3 compartments. The forward compartment contains the fuel tank. This compartment drains through a PVC pipe thru the bulkhead to the center compartment, which is empty. On my boat, there is a PVC pipe that appears to drain the center compartment to the engine compartment, but it is blocked, trapping the bilge water and preventing it from getting to the bilge pump in the engine compartment.
The boat was repowered 6 or 7 years ago (Volvo out, Mercruiser in) and I suspect that some bulkhead work was done and that they inadvertently blocked the drain hole in the process, unless there is a reason for it to be blocked. Before I run a drill down the bore of the PVC pipe, does anyone know of any reason why this compartment would intentionally not be allowed to drain?
Also, it seems strange that the center compartment would be empty without any removable or hinged deckplates for access to make the space useful. Any ideas about why they did this?
