PANDA GENERATOR
TIERNEY ROSE
IVE BEEN RUNNING BOAT WITH MY GENERATOR "RUNNING", "AC" ON, DOES ANYBODY SEE ANY PROBLEMS WITH THIS?? I HAVE NOT NOTICED ANYTHING YET!!! 290 CHESAPEAKE, THANX
ElyseM
highlands, nj
if you look at the instructions, the warning is to NOT run the boat at planning speeds with the seacock OPEN and the genset OFF. a running genset while under way would tend to be normal operating procedure. others will chime in.
i assume by "AC" you mean air conditioner. if so, the genset actually needs to operate under load, so that is what would be required (or other draw equipment). if by "AC" you mean the shore power switch on the panel, then your genset would not be providing power to the grid and you would then be running it without a load.
good luck, ron
TIERNEY ROSE
YES, "AC" MEANING AIR CONDITIONER, YES I KNOW NOT TO LEAVE SEACOCK OPEN WHEN PLANING
AND NOT RUNNING GEN, THANX
