Hi, if a boat has no live well could I buy a round Moeller, drill a hole in the side near the bottom and run a hose from the raw water spigot into the Moeller, then cut another hole in the other side near the top and connect a basic hose allowing water to escape off the back of the boat? I would only need this for Massachusetts saltwater baitfish. If the water keeps constantly circulating through the Moeller thanks to the raw water pump will this work (and no need to aerate)? I'd filter both connections inside the Moeller so bait couldn't get into either hose.
Thank you!
Thank you!
