- Jan 31, 2005
The Seastar power assist pump has two 40A fuses in it and GW adds two 30A fuses on the same lines at the battery.
I believe this is done so the aft fuses open first should an over current condition occurs. The fuses in the pump are a PIA to change if they blow.
I’ve had two instances where the aft fuses blew. Both times when I turned the wheel all the way into the stop. I’m thinking when I hit the stops the current rises as the system is trying to move the engines. The fuses pop and I have to replace. The steering still works but harder to steer - minor issue.
Just wondering if anyone has observed the issue.
