Hey folks,
Got the regular service done on the motors (twin F225s) by my mechanic and I'm scheduled to put the boat in this Sunday, rain or shine. He mentioned that one of the two primer bulbs is not hard and said it may have an issue starting. He didn't have a chance to look at it, but I want to do some proactive measures before he can come down again on Saturday evening. I put some more fuel in the boat the other afternoon on land to check if one of the fuel tanks (main tank holds 156 and the aux holds 150 which I assign each motor to separate tanks for weight distribution) was low (as I like to empty most of it before the winter so that I can put fresh gas in the spring). I started pumping the ball and I do hear fuel going in. Mind you, the bulb isn't deflated at all. It's just the one is rock hard and the other I can squeeze with just a little resistance. Could it be the fact it was just sitting on land since last October? I'd like your input on what I should do/get before the mechanic returns? Should I pick up some primer bulbs?
Thanks,
Mike
Thanks,
Mike
