- Aug 5, 2008
Prior history of symptoms:
I had a small leak on the port side of the seal which wasnt too bad. I did some research and found no visual problems/dents on the rod and decided to order the kit to fix it. Installation was a @!$@ due to the bolts not wanting to budge. Now it leaks more than ever!!! I actually have to put a rag under the the leak so as not to create a slick. fortunately there is a splashwell on my Grady (272 sailfish with euro transom)so I can get it before it enters the water.
Question:
Is the seastar cylinder out of position? Does it need to be re- aligned after replacement? If so how? With engines running I go to rear and look at the seal, It seems to pulse?
Sorry to be so long winded but i figured a better response if everyone knew what i know. Which is not much at this point.
Question:
