I think we're going back and forth on our posts! Anyhow, our boat, also 282 2002 with the f225 four stroke, came equipped with a relatively unmarked set of stainless 15.5x17" wheels, with the port prop having a shattered blade. The seller equipped with re-hubbed Yamaha SWS II stainless 15.25x19." We run the boat relatively light on fuel most times, and we see 5600-5700 WOT with two or three people aboard. On this topic there's a lot of strong opinions, but with the number of variables in play, if you're within 2-300 RPMs of 6000 and regularly exercise the twins, should be ok.
I think the 15.25x19" is what the boat was typically OEM equipped and tested with.
The other strong opinion is either a 3 or 4 blade 15.5x17, which will often run closer to the ideal 6000 RPM WOT if you load the boat up heavier.
