I hope someone can give sound advice please. Have a 2003 Grady Seafarer with OEM pulpit. The lamininate has cracked and a few pieces have fallen off after someone dropped anchor on it. Structurally the pulpit is sound and solid. Can you please recommend the procedure to repair properly and cosmetically prep,proper filler and gel coat to appear well . Have worked with spectrum gel coat in small patches over the years. Polyester,epoxy or vinylester as filler then gel coat on top? I do know that depending which filler you use either allows you to top with gel coat and some don't trying to make this as easy as possible but have good results any light You can shed is deeply appreciated with detailed materials and process I know if I don't address this eventually the solid material in the pulpit is going to deteriorate still looks solid and good thank you so much all of you!
