- Jun 30, 2008
- Farmington Hills, Michigan
- Adventure
been meaning to ask this...
I just purchased this boat. The system has a connection for the hose and the switch for it in the splashwell which I thought was rather odd.
Is this the factory location or was this an add-on? I bought one of those white, lightweight hoses for it, I just coiled it up in the splashwell in front of the motor, its not going anyplace but just seems weird.
The other question is I assume you just flip the switch to turn the pump on and use it and when you are done turn the pump off? Is there no pressure switch that will turn it on or off as the pressure is needed?
may sound dumb, I haven not tried it yet and Im sure the answer will be obivous when I use it...
thanks
thanks
