Does anyone have any experience with remote control spotlights that can be stowed when not in use? These spot can be mounted into a perko socket which accepts a stanchion (pole) in which the spot is attached. Basically, you can put spot in when you need/want it. Operate it by remote and then remove and stow when done. This is ideal for a bow mount to eliminate glare from a hardtop permenant mount.
http://www.magnalight.com/pc-932-23-gol ... white.aspx
Golight Stryker Boat Light GL-3100-S-12 Wireless Remote Light - Stanchion Post Mount -WHITE
