Remove seat cushion on extendable lounge seat on 275 freedom
Genobg
The seams on the cushion on my 2012 Freedom 275 extendable lounge seat are coming apart. How do I remove the seat to take it in for repair?
I find GW mounts things fairly basically. You'll have to inspect things and find out how it is bolted to either the deck or the cabinet riser that is part of the deck. Usually some thru bolts.
wadeatl
Extend the lounge all the way then lift up the cushion of the lounge seat and you will see an access port. Pull the port cap and you reach in and you will feel a pin and cotter. It helps to have someone help hold up the seat or have something to prop it up.
