Removing bolster cushions?
grady23
Maryland
Hi folks, I have a 1997 Gulfstream that needs the bolsters recovered. Anyone tell me how they are attached and how to remove them without damage??
Look on the bottom side near the brass weep hole. You will find a small screw on each end. Remove these first. The bolsters are attached via J brackets. Once the screws are out, push up from the bottom or side. They should slide off the J brackets (slide straight up).
Reactions: Halfhitch
Thanks much for the info. I thought they were bolted in from behind. This saves me tons of trouble. Have a great season.
Reactions: RussGW270
What he says ^^^. I did it last weekend for the first time.
The last time I removed mine the boat was 8 years old and the brackets were literally crumbling due to rust build up. Luckily my GW dealer had them in stock. Never took the time to search but it may be worth it to look around for some 316SS ones.
