I never knew that Grady used brass plugs in their brackets .. that is until yesterday when I grinded all the paint off a bracket to repaint it. Tried to remove it w/ the correct size Allen key but that did not happen. Thought the prior owner jury rigged it this way. I am use to the plastic plugs /w the 'O' ring setup.
Aside from heat which will destroy the new paint that is now being applied, has anybody drilled and tapped one of these things out? Any tap size info and or tips?
Thanks.
Thanks.
