If you are referring to the bolsters on the deck, they are slid onto metal brackets and then screwed at the bottom through a few of the grommet holes on the underside of the bolster. You need to find which grommet hole has a screw and then poke around in the hole to find the screw head (philips). Getting them off is a challenge. Getting the screws back in is sometimes even more of a challenge
