Replacement AC Raw Water Sump Pump
Jamato14
Looking for a replacement pump to run my AC off raw water. Dayton pumps no longer in business so looking for something with same voltage, input/output plumbing size and ignition safe as it’s located in forward bilge. Haven’t had any luck online or at local New England stores, any help/insight appreciated.
Jamato14
Sorry quality of pic is bad. Specs: Dayton model: 1P808A 115v 60HZ 1.5amp thermally protected
Sibs
Falmouth MA
I have one from a 330 express if it would work for you?
Jamato14
Sorry just seeing this. Looks like it will work but do you have specs (intake valve size and if it’s male/female?, outflow size same questions?, voltage and amperage?)? PM me I’ll share contact information and give you a call to confirm if it’ll work
Sibs
Falmouth MA
Inlet 3/4”FPT, outlet 1/2” MPT. 115v 50/60HZ . 2amps , Flow 8.5GPM, max head 19’, magnetic drive
Jamato14
That should work perfect. Shoot me a PM if you’d like and we can discuss price/pickup
