Replacement Dome Light
Gulffisher
The helm dome light on my 330 express recently died for the second time. For replacement this time around, I went with the Lumitec Aurora in the white/red option. The new light covers the existing mounting holes and needed only minimal work for the new wires to pass through the mounting surface. Reinstalling the bezel per the instructions was a bit tricky and Lumitec might consider creating a detailed video showing how the bezel "easily" snaps back on.
Yes, this light is a bit pricey but it is very nice. You turn the bezel right or left to select either red or white (no more switching through one color to get to the other) and you can dim both color options by rotating the bezel beyond the initial on-positions. The light remembers your last brightness setting. You may consider this light or something similar when you tire of your old OEM style dome light. I hope GW is using these type lights on their newer builds.
