Not too long ago I had to replace the brass (or bronze?) thru-hull's that are for the 4 scupper drains at the transom because they were corroded and paper thin. I had to rent a tool to "SQUISH" them down to make the flange for them to fit properly. Kind of a pain and very messy with "LIFE-CAULK" all over the place. Well now I noticed that ALREADY they are "TOAST" and need replacement again ! Now I even have to do the bilge drain too !
First off is there an easier / better /proper way to do these ?
And shouldn't they last MUCH longer then this ? Is there a better quality fittings I should be using ?
I also wonder if taking the scuppers off in the winter-time would be a good idea ? They always seem to clog with debris in the winter and let water SIT in the scuppers.
