- Jun 30, 2008
- Ocean Pines, MD
- Express 330
Have a ‘06 330 and need to replace the 1” bronze ball valve on my waste holding tank pump out. Grady recommends replacing it with what is there already (pic #1). However, I’m considering replacing it with Groco IBVF/C83600 bronze (leaded red brass/85-5-5-5) flanged adaptor w/backing block between the valve flange and the hull. The valve is located in the forward bilge and protected from anything coming in contact with it so
I’m wondering if this is overkill? Also, the Groco valve on there now says 600 WOG but the valve I purchased says 400 WOG. Not sure the difference? I will also be doing this on a lift and only have 8 hours from being out of water.
