Rust at through hulls
Tinny
Vancouver
Hello,
Wondering if anyone else has had this issue - recommendations. Something to worry about or normal?
Earlier this year bought a 12 year old 282 sailfish. Boat was lift kept and there were no signs of rust at the through hulls. Survey showed port side as being dry, with a little bit of moisture on the starboard side around through hulls but was told nothing to worry about.
In any case, boat is now moored full time and have noticed some rust forming along 3 of the 4 deck drain through hulls. Not quite sure what is going on or what should be done.
Thanks,
Vince
That looks like "bleeding" from not having the thru hulls properly bedded (or perhaps they need rebedding). But I'm a bit more curious as to why the port side seems to be lower in the water than the starboard? Or is that just how you're leaning over the side to take the pics? Does the boat sit level normally? I'd expect the thru hulls to be above the water at rest.
Yeah - it is just me leaning over to take the pic. Boat sits level and thru hulls above waterline - although I am surprised at the number of slightly older grady's in my marina whose drain thru hulls do not sit above the water line.
Ah cool - that's good! Yeah, looks like crevice corrosion. There's great info on the need to bed fittings here: https://www.gemlux.com/faqs
re: Older gradys sitting low, they may have been repowered with a heavier 4-stroke motors... Some ballast in the bow would probably help, but most folks hate the idea of adding weight.
Reactions: RussGW270
If possible take a look at the back side of the fitting to see if there is excessive rust. You want to make sure the fitting is structurally sound. Other than removing and rebedding the fittings, there isn't a lot you can do other than clean up the stains and relax:)
If their outboards and have been repowered the newer ob’s are a lot heavier that what was made 10-15 years back. That’ll contribute.
it also can be the SS thru hole. They will bleed a bit (very common on GWs). Have someone look at it. Probably nothing to worry about.
