- Mar 29, 2013
The port side scupper plastic deck flange/tube fitting has corroded. The flange has completed separated from the tube that fits into flex hose on one of the scuppers and the other is about 50% corroded around the circumference of the tube. Access thru the storage compartment and removal of the drop-in box seems like a difficult reach. I'm thinking that I'll need to remove the deck cover plate over the fuel tank to gain decent access. The two starboard side scupper deck fittings are currently intact, but I'm assuming they will corrode through at some point also. Interested if anyone else has experienced this problem and how you gained access to replace the deck fittings.
