Seafarer 22 1990 or 1991 rear bildge
captainsml
Does anyone know how to access the rear bildge pump of 1990 or 1991 Searfarer 22 to pull it out and replace?
NikM820
Daytona Bch Florida
You have to take out the live well. Not to bad, the worst part is the lower drain hose. Getting that one on and off was tight.
Got Grady?
By the sea by the sea by the beaut.......
Be careful the bottom of the livewell on mine was so thin the fitting broke out of the bottom along with the surrounding glass. I had to glass over the bottom with several layers and redrill the drain hole. Then when I went to replace the hose the thru hull broke off from the other end. Mine was plastic and original so if yours is newer or brass you should be ok on that end.
