- Jan 9, 2022
- Chesapeake Bay, Maryland
- Seafarer
What I decided is to replace the thermostats, impeller, spark plugs, and poppet valve. Then check coolant passages for buildup causing the overheating concern at higher rpm. If everything checks out internally I can gain about 25hp from replacing the heads and carbon fiber reeds from Hydrotech so that is a decent bump and will squeeze more hp out of the engine until I fully commit to a newer boat thats a little bigger in size.
And yes - the fake teak is bothersome to me as well. I’m looking into either replacing it or painting it.
