Sealing the large deck plates
GW VOYAGER
Bainbridge Ga.
I need to seal the large deck plates on my voyager and need to know what sealant should I use?
I read on one forum not to use some types because they are hard to remove when you need to gain access at a later date.
Something about West Marine 4200 or 5200 was stated.
Any Help?[/b]
BobP
GE Silicone II window and door on gap, your color of choice.
Fill gap, don't bed it.
Add 100 lb mono in gap prior.
Use BoatLife Lifeseal on screw holes.
GW VOYAGER
Bainbridge Ga.
Bob where do I purchase life seal and are you talking about 100 lb.mono fishing line to fill the gap before applying the sealant?
gw204
St. Leonard, MD
I use 3M 4000 UV on the gap and seal the screws w/ 5200. Both of those are easier to clean up than silicone.
NOTHING ELSE MATTERS
LONG ISLAND NEW YORK
The mono is used for just in case you want to remove the silicon later, all you do is pull the mono along the gap and cuts the silicon.
