Well, a quick look at chart 12352 seems to show a variety of bottoms in GSB, including mud, sand and grass.
No one anchor is "best" for all bottoms. Danforth style anchors are good in mud and sand, due to lots of fluke area, but can skip across grass instead of digging in. Plow anchors are better at digging through grass, but can drag in soft mud.
Regardless of the style of anchor, I would recommend getting the next size up from whatever is recommended for your boat.
The shallow depths of GSB wouldn't require much rode, but I would always recommend getting the most that will comfortably fit inside the anchor locker. That will depend on the diameter of the line, and the type of line - you can get twice as much 8-plait as you can 3-strand, of the same diameter.
Chain recommendations can vary a lot, but the best rule of thumb is chain length equal to boat length. If you are almost always anchoring in shallow water, then you can likely get by with 15-feet.
The comments above are JMHO, but they are based on over 50yrs of boating, starting in Little Neck Bay in the late '50s.
Brian
Commander, USN (Ret)
Master, Oceans, Steam, Motor or Sail, 1600-Tons
Chief Mate, Oceans, Unlimited.
To put it all together - I would recommend at least 200-feet of 1/2" 3-strand nylon, or 300-feet if you go with the 8-plait. (Yes, more than you need for GSB, but nice to have off the south shore, or up in LI Sound).
For chain - at least 15-feet of good quality 1/4" galvanized chain. More is better.
For the anchor selection, here is some good info:
http://www.anchoring.com/article_info.php?articles_id=4.
If you go for the "danforth-style", then get the Danforth. Always been better than the knockoffs. I strongly recommend the "H" series, instead of the "Standard" anchors.
So, what do we have on our Islander 270? A 22# Delta Quickset, with 30-feet of 1/4" chain and 600-feet of 1/2" diameter 8-plait . That's for the main anchor and rode. The "back-up" anchor is a Danforth 12H, kept in a bracket on the bow. The rode for it is stored under the port side of the V-berth, and is 200-ft of 1/2" 3-strand and 10-ft of 1/4" chain, with a shackle all ready to bend to the anchor.
