Size of Thru-hull on Fisherman 204
gradyrod
Long Island,NY
Does anyone know the diameter of the thru hulls at the aft sides of the Fisherman 204? I want to replace them this year and install a ball valve as well to be able to shut them when I'm at the dock.
Thanks!
Gradyrod
1985 Fisherman 204
cedarholm
Birmingham, MI
You can contact Grady-White direct.(Include hull#).
Can you measure from inside?
Are you talking about the scuppers? (With external flaps?)
Thanks!
Gradyrod
1985 Fisherman 204
One of those is the bilge pump outlet. You don't want to put a vavle on that.
gradyrod
Long Island,NY
Thru-hulls
I am referring to the two thru hulls on either side that exit the hull at the aft end right at the water line. (Iam not referring to the scuppers in the transom with flappers). They serve to drain identical lockers, port and starboard out to the sea.
