Besides adding new Battery 1-2-Both switch and a second batt, I want to run a new wire from the Battery common on the new 1-2-Both switch up to the electrical panel. Can someone tell me what size wire should be used. Can I use 10 ga. for this run (15 ft each way, 30 ft total), or do I need larger? I wonder what Grady sized this feed wire at? My accessories include VHF, fishfinder, horn, bilge pump and deck flood light (5 amp draw).
Also, can anyone recommend where to buy replacement toggle switches to put in the panel? The existing ones are pretty corroded.
Thanks.
Rod
1985 Fisherman 204
Thanks.
Rod
1985 Fisherman 204
