Might have been me referring you to patriot marine.TB2BLAZER,
My tank was not yet leaking, but on the verge. Cost me $800 plus shipping for a new 90 gallon tank for my Seafarer.
I got the dimensional drawing from Grady White customer relations by email.
Another member suggested Paul @ Patriot Marine Fabricating in NJ (609) 693-5542
Awesome manufacturer to work with and somewhat close to you.
I did the install myself. It's not rocket science, but gritty.
LeeView attachment 12758View attachment 12759
Mike,Might have been me referring you to patriot marine.
I had a 60 gal tank fabricated about 6 years back and I think it was $600. The guy is good and he gave me the cheapest price.
He gave me a time frame for it being done and met it without any games. First rate job!
That is terrible. The ethanol damage to the boats in your area must be off the charts. Is that a city or a state restriction?Can't get non ethanol gas in NYC![]()
Not to nit pick,but octane hydrocarbon fuel is hydrophobic and alcohols are hydrophilic. I do not know what this hydroscopic thing you speak of..lol. The hydroxy molecule, OH, on alcohols will bind with water.I am not sure. Honestly though, when ethanol was mandated, there were issues especially on certain fuel hoses. That was years ago and at my club, I don't see a lot of E10 problems. I do hear every now and then about water in the gas but in almost all of those cases, it was either water intrusion or a bad load of gas. The problems are greatly exaggerated in my opinion.
I have used gas stored for 2 to 3 years in a boat with out issues. If it doesn't smell awful and you stick the tank to check for lots of water, it is probably OK for general use. Yes there are some potential corrosion issues and some older hoses and gaskets that don't like it but the majority of those have been addressed.
The condensation debate will go on forever but I think back to the old days when folks added DryGas to their tanks to deal with moisture. DryGas is mostly alcohol! Many will point out that E10 is hydroscopic meaning it it absorbs water and that is true but if you add water to non ethanol gas, it sinks to the bottom anyway and after a while will build up to a point where it gets sucked into the plumbing. In some respects ethanol gas handles a little water better than non ethanol fuels
One real issue with E10 (and other blends of ethanol) is the possibility of phase separation. That can occur when a lot of water gets into the gas and can be a serious issue. I do not see this all that often in recent years.
Could be. We might find out this season since the past winter here in NY was pretty warm on average. Let's see how many folks break down or can't start their motors.Down here in south Florida, at least 35% of my repairs at my outboard shop was an ethanol problem. Our humidity and the heat is off the chart all year around. Without stabilizing, ethanol gas lasts about 4 months before it smells bad. Non ethanol lasts 10 to 12 months before it goes bad. Every marina and many land based gas stations have non ethanol. I use it in everything I own except my tundra. All my lawn equipment and pressure washer has been going strong since 2008 without 1 fuel problem. Must be the cooler temperatures up north that help fuel last longer and not so do much damage.
