- Mar 22, 2012
i just replaced all of the deck drains, thru hulls, and the weird little vent (that could sink you) running from the motor well to the cave just above the trim tabs on the bottom of the hull. -great! i cut an 8" by 11" hole to fit an access hatch of that size in the vertical wall behind the transom door on the starboard side. WELL you can see the scupper outlets and that very end of both hoses, feel the closest deck drain, but with all my might can barely stretch to feel, nevermind remove the hose, or replace the deck drain further away. i am very disappointed in any boat manufacturer namely grady white that stops here in their engineering skills-------------so now what do i do ? these need to be replaced! come on grady step up to the plate, pay for someone to do this for me! it's going to have to be houdini, my life is in your hands i await your response, how many sailfis have already sunk because of your engineering skills?
