I am trying to install a Sony stereo on my Gulfstream and I can't seem to figure out the wiring. This "should" be a simple install as I am only utilizing the head unit and 2 speakers. Based upon the wiring diagram I should only have to utilize 3 wires (black, red, and yellow). The black ground wire is easy and I have that part down. The red and yellow wires are both positive and this is where the issue lies. The red wire states that it should be connected to the +12V power terminal which is energized in the accessory position of the ignition switch. It also says, that if there is no accessory position, connect to the +12V power (battery) terminal which is energized at all times. The yellow wire states that it should be connected to the +12V power terminal which is energized at all times. I know it should be easy to install but I'm not sure whether both yellow and red wires should be run directly to the battery or if one or both should be hooked up through one of the two available accessory switches at the helm. I installed all the other electronics on my boat, which include radar, gps, vhf, and fish finder and I must admit that I'm almost embarassed that I can't figure this out. Any help would be greatly appreciated as I hope to tackle this task this weekend.
