Switches for dome light, spreader lights
doug228
I had no trouble finding the push button switch for the spreader lights (mounted in the dome light, 2 wires). But had no luck locating the switch for the dome light,.
Needs a 3 wire switch....anyone know where to find one?
Digikey.com shows stock @ $12.09. If you need the spreader light switch use the 512PB-ND - higher amperage. I don't really care for the boots - I use them but they are a little short and interfere with the switch.
www.digikey.com
512PB-ND 10-amp SPST for spreader lights
40-4325-00 Judco Manufacturing Inc. | Switches | DigiKey
Order today, ships today. 40-4325-00 – Pushbutton Switch SPST Standard Panel Mount, Rear from Judco Manufacturing Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
www.digikey.com
522PB-ND 2-amp SPDT for alternating red or clear courtesy light
40-3657-00 Judco Manufacturing Inc. | Switches | DigiKey
Order today, ships today. 40-3657-00 – Pushbutton Switch SPDT Standard Panel Mount, Rear from Judco Manufacturing Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
www.digikey.com
532PB-ND Switch boot
19-1082-01 Judco Manufacturing Inc. | Switches | DigiKey
Order Judco Manufacturing Inc. 19-1082-01 (532PB-ND) at DigiKey. Check stock and pricing, view product specifications, and order online.
www.digikey.com
www.digikey.com
523PB-ND This is a On-Momentary switch. THIS IS NOT WHAT YOU WANT!
40-2531-01 Judco Manufacturing Inc. | Switches | DigiKey
Order today, ships today. 40-2531-01 – Pushbutton Switch SPDT Standard Panel Mount, Rear from Judco Manufacturing Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
www.digikey.com
same here. the 10a for the spreader was in stock. the other not.
Digikey shows 327 in stock to ship immediately for 522PB-ND 2-amp SPDT for alternating red or clear courtesy light @ $12.09.
Sometimes it just the boot. Take it off and see if the switch works every time. If yes get a long boot at marine store.
doug228
Both switches where toast, I did the spreader o. Already. The boots I got are garbage so I will look into better boots. Left them off for now. Will order the SPDT switch for the courtesy light.
Thanks for the help!!!
