Thanks, Yamaha Engineers
Daman858
Pawleys Island, SC
Well, the Yamaha engineers saved me from myself.
After rinsing out my F200 on my Adventure, I neglected to twist the water line connector tight. As I ran the boat, unbeknown to me, the thing was leaking pretty bad, then came undone. My engine dropped back to 2000 RPM and the overheat alarm came on. I shut her down quickly, discovered my error and properly connected the fitting. I anchored up for about 30 minutes to let everything cool down, started her up and ran slowly back to port. The marina mechanic checked it out, said those sensors will set the alarm off long before any damage is done. He and I ran her at 4500 RPM for about 1/2 hour, no problem.
Lesson learned...check out the boat and motor carefully BEFORE starting out.
Glad that turned out to be a cheap lesson. The "walk-around" is something that good pilots do and good boat owners should also do. "I thought YOU put the plug in" is always one of my favorite things to say when I go out with a friend. It gets a GREAT response.
