Excellent advice from Bob above!!
Also, go through basic things many overlook, check your running lights make sure you do not need bulbs, check the batteries to make sure they hold a charge. If your unsure of how old they are, might be worth considering new ones so they do not crap out half way through the season. Make sure your vhf works as well. Greese all fittings on the engine and trim unit, once it's in the water it is hard to do. Make sure your windsheild wiper works. If you have canvas's, check for rips, lube all zippers so they slide well and clean the clear plastic with proper cleaners...not windex or a household cleaner, but a marine one made to protect and wax the plastic and keep it protected from the salt.
I agree 100% with bobP, use a fuel addative, I have used startron for years and have had no fuel issues. A 10micron filter from Yamaha or Racor is the way to go, do not use a no name west marine brand, had them one year on the other boat and they had issues. Ringfree is also well worth it, yes it is expensive, but it does work and keep the engines mechanicals in good order.
Also, always keep a spare gallon of oil onboard, it goes fast when your having fun and you can never be too cautious, having it onboard can save you a costly tow, or extensive damage to the engine. Always keep it above 1/2 is my advice, or even 2/3 if possible.
Enjoy the new boat!!!
