Wow, this is a debate that lives on and on. Just when I though I had made a decision, Steve Bradburn at Furuno has managed to change my mind. Looks like I am going to put a hole in the boat and make a few modifications to my trailer bunks. Here is what Steve had to say:
Ken,
Thank you for your email.
As you probably know there are pros and cons to both in-hull and thru-hull transducers. I favor thru-hull transducers. There are two disadvantages with in-hull ducers. The first is the signal loss that happens when you shoot though the hull. The second is the bubble or turbulence layer that will pass over the face of the transducer when the vessel is moving. Granted there are success stories from folks who are using in-hull transducers but I have been on a lot more installations that haven't worked than have. Very rarely do you ever see a vessel that has both in-hull and thru-hull transducers but attached is a picture from a vessel I was on in Cabo. The thru-hull transducer was a 1Kw 50Khz and the in-hull was a 2Kw 28Khz. The 28Khz should have blown the socks off the 50Khz, especially in 100ft of water. But as you can see that was not the case. If you are spending most of your time fishing in depths of less than 1200ft I would recommend a Airmar B-260 with the high speed fairing block.
Kind regards,
I will post the picture later...
Ken,
Kind regards,
