So, I there are a ton of posts on this subject here, which have all really helped me out...however, I encountered a problem today in replacing two of my thru-hulls that I hadn't seen a post about....so i wanted to post my experience and see also, if anyone has the same.....
Today I replaced the aft bilge and starbord fishbox drain thru hull. The original plastic ones literally disintegrated in my hands when my new/used 1997 Voyager 248 arrived here from CA....
On both of these thru hulls, I found that the thickness of the hull/glass was greater on the lower half of the thru-hull hole than the top half. This resulted in me having great difficulty tightening the new stainless/bronze thru-hull fittings. What would happen is the bottom (thicker) part would cinch first, and cause the top (thinner) part to separate-- with the end result being a thru-hull where the outside flange was not flush with the outside of the hull all around. With the stainless one I installed (came with a nylon washer) the washer squished up to the top side.
We ended up solving the problem by crafting some shims to fit between the top half of the thru-hull nut and the hull, allowing equal pressure to be exerted on the hull, thereby pulling the thru-hull fitting in evenly and flush.
Has anyone else experienced this? How did you deal with it?
I will be replacing the remaining thru-hulls next winter (doing just enough this season to get me on the water by May 1).....any info is appreciated!
Thanks, and tight lines.....
