I'm going to replace my thru hull fittings this spring. I noticed a bit of water is leaking into the boat and suspect they're the cause. I've read that stainless is the way to go. My 1987 overnighter's plastic thru hulls lasted 23 years. Is it worth the extra money to go stainless? Is the issue w/ plastic it's longevity due to UV or are there premature failures as well. I'm not so sure this boat will be in commission in 23 more years
