I would always replace my thru hulls as needed with the standard Perko plastic replacement ones since in the older hulls access was much more difficult than with the SeaV2 hulls.
I am now lucky enough to have newer hull, so access is much better and I would like to perhaps switch to Stainless this time around. Attwood seems to match up almost perfectly but which fitting did you guys use to replace the deck drains near the helm both port and starboard?
They are the ones that Grady finessed with the grey plastic elbow fittings. I would hate to have to go through cutting the Stainless new thru hulls just to match up how they did their install. May even just leave these as plastic ones..
Thanks for the assist
