Hey anybody out there that owns a Tigercat looking for some info I took the boat out today in 2 to 3 did not fill a thing but in calm water tends to list when your over 4 thousand rpm any info would be Great THANKS
I've recently read older articles from test runs that talked about the need to properly trim (read it on this forum as well), with tabs and motor adjustments, to get the best balance out of the F26 hull. Also, at 4000 rpm you're likely pushing 30 mph and riding high on plane so weight distribution will also play into factoring. Either way I suspect you'd be able to trim it level.
