- Aug 1, 2018
- Tournament 307
1. I noticed both the aft and forward bilge pumps are not positioned in the "lowest" part of the boat. Most of my bilge water settles about 4 feet to the rear of the forward bilge in the inlet and outlet seacock compartment for the head. In order for the forward bilge to even think about kicking on, a whole lot of water has to end up down there. Same for the rear bilge. It is not positioned in the lowest part of the boat. Although from what I see, there is really not another place to put it back there because of the water tank. However, I would really like to know why Grady did not wire a forward bilge in the sea cock compartment. It is very accessible.
2. As for the anchor compartment - I do not understand why there is not a little self bailing through hole at the bow of the boat to allow any water to drain directly out that comes into the anchor locker. When you bring up 60 feet of anchor line, it is socked with salt water and it drains directly into the bilge. On my other boat, I used to hose down the anchor locker to get all the salt off the chain and it would drain right out of the boat. Why would you want all that water into your bilge if you can avoid it?
Anyone else have a lot of rain water in their bilge? Any feedback on the above would be greatly appreciated.
