- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
Of course - you're welcome! A lot of the things I talk about are based on "truths" I've found over the years. But that doesn't necessarily mean it's a "truth" for everyone - so always take my ramblings with a grain of saltDennis. Thank you again for all of your information and knowledge. I truly appreciate it. With everything that you've said and what others have said, I definitely will be buying a trailer with EOH.. I actually got a quote yesterday on an All Marine. Triple axle. 15000 GVWR with EOH, which I know is extreme overkill, but the price really was not that surprising to me. It was less than actually some of the tandem axle trailers that I've been looking at, and this would be a new custom build as well.
Something to consider... going with a higher capacity isn't "always" better. A higher capacity trailer often leads to a rougher ride for the boat. Being 3K over at your weight, though, isn't as bad as being 3K over with a 5K boat.
As noted above, check out the components used in the trailer - they all look shiny when they're new, but you want something that will be reliable. I don't know anything about All Marine so I won't comment one way or the other. Also... will you have easy access to warranty repair if needed? Meaning, it's best to buy local.
