transom mount trandsducer cable on a 232 gulfstream
captainmichael
I need to route a cable from a transom mounted transducer on a 232 Gulfstream with a twin motor mount with swim platform. The route around the platform is quite long. How do you recommend the cable get routed through the transom? Suggestions that have worked? Any one take it into the motor mount well and then into the transom from inside the motor mount well?
ROBERTH
Raleigh, NC
Run around swim platform flange, secure with cable holders, then use D-shell to run through transom just under platform, as high as it will go. Fill with 4200. In the last pic, you can see the D-Shell location. Sorry, didn't have a better pic of this detail.
captainmichael
Thanks for the response. I appreciate the time you took to attach the photos!
darkarcher
Has anyone mounted that Skimmer in the bilge and shoot thru hull?
Mine is mounted a bit further out and I have had issues with it losing signal and having to reboot after high speeds.
