transom question
Rock Creek
Can any one explain to me what the differance is between a plain transom, a bracketed transom and a "euro" transom. Just getting started trying to sort out the right Grady for me. Thanks
uncljohn
A plain transom (normally "notched transom") is a straight flat stern with the motor mounted directly to the stern. Grady 226
A bracketed transom has some sort of motor bracket mounted to the transom, which holds the motor back 1-3' from the transom. Grady 228
A eurotransom has what I'd call a step-down from the actual transom to a platform to which the motors are mounted. I think the Sailfish has this now?
A notched transom is not desireable if you fish in big waters where you can get waves over the stern. But it can be done.
Clockwork
notched transoms get knocked but i like them and there is a simple fix: bolt in a plate into the cockpit side of the engine well. thats what i do.
i dont like brackets because it makes the engine hard to access from the boat (emergency repairs etc). and they have steering characteristics i dont like.
Legend
Southern New England
Ive had all three transoms - A Seafarer (notched), Gulfstream (bracket) and Sailfish (Euro) - While it is tough to compare just the transoms because of the different sizes in boats, I had a much better sense of saftey with the the latter two transoms - backing down on a fish is a bit nerve racking in the notched transom - Although I have to say I had the notched for 18 years and never had a safety incident - just feels more secure with a full transom
DaleH
Newbury, MA
Basically with a Euro transom, say for a 23' model, you'll get less room of the previous 21' model of that same boat ... but at the price level of a 23' boat. Or simply put, less room - more cost. Less room overall if one counts the 'new integrated pulpit' into the length too.
Seriously, not that GW does this as blatently, but there used to be a website that showed the old 20' Pro-Like CC, where it progressed to be their new 22' CC model with the Euro-transom, which then became the next year's 23' model with integrated pulpit. Ahhhhh, it had less cockpit space than the old 20' CC model with cut-out transom. But note, every foot greated you go in hull length adds $1,000s to the baseline price.
Sometimes though, you will get an increase in beam to the hull under the new configuration.
Others can opine differently, but all I know is that my 25' Parker is 25' from stem to stern, adding 3-4' for the OBs off the engine bracket and another 3' for the pulpit, and my 25' hull measures almost 32' overall ...
