Trim Pieces
Sjhopeiu
Florida
Does anyone have a good source for replacement corner covers such as the ones in the picture?
Get your bang plate replaced! Will run you about 800$...well worth not getting a soggy transom.
Looks like somebody did a patch job there.
You can get the newer vinyl bang plate from Grady. It's not cheap but under $100. You need to cut it into 3 pieces to make the corner junctions. They told me to seal it with 5200. I did that when I recently repowered. My transom was as dry as a bone.
You need to gets your transom checked out before just replacing the bang plate. It looks scary.
I ordered mine from a Grady dealer, direct shipped and not exorbitantly expensive. They are specific to model.
I think wspitler is spot on. They are likely a custom formed part. You'll only get those from GW via a dealer.
Keep in mind, the pieces are cosmetic only. The key is to make sure the joint underneath is sealed and the piece (including screws) are sealed when mounting.
