It took several attempts to get my Yamaha F225 to go down the other day. The tilt was working fine as was the port trim piston. The starboard would not retract. After several attempts, it worked fine the rest of the day.
I'm sure one of you will know exactly what the issue is after looking at the photos (first is the one that was stuck, second is the other -- as if you couldn't tell).
Is this a big deal or an easy fix. Can it wait or should I hold off on using it?
Thanks!!
- Robert
Thanks!!
- Robert
