TV/DVD help
devildogdad
Ok , again brand new Marlin. Boat came with the tv/dvd combo. No genius here but i put the tv on, select av input, turn on dvd player, put in dvd, press play and NADA. tv says no signal. tv has no other inputs, it is either tv with cable, antenae or av. there is no other av2 etc.
any thoughts, trying to go thru a ton of paperwork to find an answer.
yes it could have been caught at sea trial, but after several hours of going over the engines, genset ac etc and needing to beat out a storm on the way back to my marina it was back burnered and overlooked.
is there some special setting I am missing.
devildogdad
might, have the solution, but i wont be to the boat till next weekend. Looks like i have to set the dvd player to dvd, sd card or usb input. most likely that is the cause. i will let you know.
