I have a Shurflo Problaster pump that functions in both capacities through a Y valve at the stern. When I switch it over to washdown the fuse blows on the switch panel. If I operate in the baitwell mode it does fine. Today the pump wouldnt work in either capacity
When I flip up the toggle switch at the swith panel, the indicator light comes on but I do not hear the motor to the pump running. I checked the fuse and it is ok. Any suggestions on how to check if the pump is burnt out or not
