I’ll check it out, thanks.My 1994 pump in in the tank. . not sure if they move it , but look under the rear berth deck panels and the tank should be there. It's a messy job working on the pump.
Thanks for the pics.Pulled mine out and it looked like this - seized as well. I was going to throw it away, but an hour later it was purring - smooth and strong, bearings felt like new. It was probably replaced not that long ago, as everything looked fine once it was cleaned up. I've heard that it can be a nasty job, but it wasn't bad on this one - apparently the holding tank just had old water in it.
I read about this, and as many people said the only problem was seized pump. It followed the normal protocol - triped the breaker when you try to turn it on - but a good cleaning was all the system needed. Works like a charm now.
Pulled mine out and it looked like this - seized as well. I was going to throw it away, but an hour later it was purring - smooth and strong, bearings felt like new. It was probably replaced not that long ago, as everything looked fine once it was cleaned up. I've heard that it can be a nasty job, but it wasn't bad on this one - apparently the holding tank just had old water in it. I read about this, and as people said the common problem is/was seized pump. It tripped the breaker when I turned it on - but a good deep cleaning was all the system needed. Works like a charm now.
