Windshield washer solenoid 330 Express
Comfortably Numb
Southwest Florida
Does anyone know the location for the windshield washer solenoid on a 2017 330 Express?
The solenoid opens when the three way switch at the helm is pressed down to operate the wiper and the water spray.
Mine seems to be stuck in a partially open position that allows water to keep spraying from the wiper even after I turn the switch off
The only way to stop the water flow is to turn off the main water switch and relieve the pressure in the water lines by running a faucet until all the pressure is out of the system
grady33
Ocean Pines, MD
On my 06 330, there is a little round knob under the steering that controls the water when pressurized.
seadiver07
Express 360
Have a 360 express. amazon had 12v solenoids alot cheaper then original
Comfortably Numb
Southwest Florida
I found the solenoid. It is behind the switch panel at the helm. I removed it and cleaned it, and it's working fine. There was debris built up that was not allowing the seals to fully close.
