Windsield Washer Replacement
Legend
Southern New England
Has anyone replace the windshield washer nozzle. Mine is broken off and it appears that the only way to access it you would have to remove the windshield wiper and wiper motor?
Thanks in advance
sluggoe
not sure what u r referring to.....
u mean where the wiper attaches to the base or.....?
Legend
No it is the nozzle that the hose attaches to that sprays the fresh water on the window to clean it.
reelserious
Unfortunately, the answer is probably yes. There is a slim chance that you can remove the broken screw-in nipple and screw in a new one, but if it was as corroded as mine was, then you will likely have to replace the assembly.
Renovator
Jacksonville,FL
Mine on my '05 Sailfish also broke but it now sprays directly on the windshield and still works well enough to clean the glass when needed. If I could figure out how to install a "y" shaped nipple it could get both sides of the front glass at the same time instead of the starboard side only. Has anyone attempted this?
saltypup
napa, ca
I just did this last year and from what i can remember you have to take the windshield motor out(from the back) and start there. Then you can access the broken piece to replace it, I think it has a nut on the back of it. This is from memory and I'd have to look at my boat to refresh but I absolutely remember taking the motor off. I ordered the part from crockers, wasn't expensive but it is now all plastic so I guess it wont corrode.
